rust remover :)
marz68
rust remover :)
Post by marz68 »
It's time to rid this truck of rust again but wanted to try something different other than flap disc so this is what I used. This stuff works so good and fast.
mrsnicks
Post by mrsnicks »
WOW and you just wiped/sprayed it on? Where did you get that stuff from?
More details.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
spartman
Post by spartman »
Basically its just muriatic acid.
A weak form of hydrochloric acid.
jzjames
re: rust remover :)
Post by jzjames »
Wow. Thats a good tip.
Now get some primer on that thing!
marz68
Post by marz68 »
This stuff was $13 and change and I bought it at home depot. I think i'm going to use it for the rusty frame when the time comes to paint it.
Primer is coming soon jzjames.
its also used for cleaning drains. it will work for what youve done.
Jake11
re: rust remover :)
Post by Jake11 »
Pool acid cut with water works just as good. Just don't get it on you.
Neutrilize with water and comet or ajax cleaner. Dry it with air or a towel.
Prime with epoxy. Heat it to 80deg. or more. Bullitproof.
