Installation of West Coast Mirrors
How do I install West Coast mirrors
Fishnsmith
Fishnsmith
- HOWDY69
re: Installation of West Coast Mirrors
Yes I would like know the location and type of hardware to use(self tapping screws or nuts and bolts, ect...).
Thankyou for your time
fishnsmith
fishnsmith
- HOWDY69
Mine have nuts on the top bracket and bolts on the bottom bracket so I think you may need access to the inside of the door. Maybe some one will come along who has done this before.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
After thinking about this for sometime I decided to go and look at my truck. There are marks on the doors where to drill. There are also clearence for carraige bolts at the top of the door and the nuts go on the outside. It amazes me if I just open my eyes and look little things like this make sense.
If you use the correct hardware its easy the top bolts are 1/4 in size and have a flat rectangle for the head. Now the bottom are expansion nuts or caged nuts. With out the proper tool to install them you have to use a bolt and nut to smash them in unless you get the rubber kind. to use the bolt and nut method you run the nut as far as you can go with it and screw the bolt in it to the nut then taking two wrenches turn the nut in the off direction. This will make the nut expand and seat You can get the caged nuts from lowes or home depot they both have auto fasteners. Any one of these will do the job for you
http://www.efc-selfretainingnuts.com/pr ... ,208,33736
http://www.efc-selfretainingnuts.com/pr ... ,208,06636
http://www.efc-selfretainingnuts.com/pr ... ,208,33743
Foggy
Foggy
- Finleyphoto
HOWDY69 wrote:Mine have nuts on the top bracket and bolts on the bottom bracket so I think you may need access to the inside of the door. Maybe some one will come along who has done this before.
I use "Molly Jacknuts" (I kid you not, that's what was on the box)
http://www.efc-selfretainingnu.....,208,33736 Yeah, that's them!
GM used a lot of these and you don't have to remove panels.
Lowes has them, but they don't have the white sealer on them.
Drill a 7/16" hole and drop one in with a long 5/16" bolt, nut and 2 washers.
You have to collapse the nut assembly and the bolt, nut and washers is your tool.
Dennis
Thanks for all the advice
- 1971ford
mine were freaky. on the bottom, there was one of those things that fold in and then pop out and stay, like what you would use to hang something from the ceiling. they were such a paint to get out. there were big square wholes there too. i just dont get PO's.
though i would share some PO stupidity.
-Ryan
