how to access a bed bolt
- 1971ford
i stood on my bumper and bounced up and down and noticed that my bed was loose! the bolt that is loose is the bolt i cant reach. it is located closest to the driver's door. i also have a under bed tank. do i have to remove the whole tank to get to the bolt? it looks like if i removed the tank skid guard, that i would have a very small chance of sliding my hand through a small space and tighting the bolt but i doubt it.
so do i have to take off the tank to tighten the bolt?
thanks in advance
ryan
thanks in advance
ryan
-Ryan
re: how to access a bed bolt
there are 8 bolts holding the bed on I doubt very much if one loose bolt will cause the bed to come off in fact you could only have two holding it on and it will stay on except in a rollover accident.
For trucks with the auxiliary fuel tank, the forward bolt on the driver's side is attached slightly different. The bolt threads into a J-nut clipped onto the frame, instead of just going down through a hole in the frame and being torqued down with a standard nut. The head of that bolt has features that'll allow you to remove it from the top...either it's slotted (for a large flat-tip screwdriver) or has the Torx-type head, for removal with a large Torx socket.
However, there's probably enough rust on that bolt and J-nut that you'll never be able to simply thread it out that easily from the top....which means you'll probably still be looking at dropping the tank so you can at least soak the heck out of the J-nut with some PB Blaster for a week or so. More than likely you're going to have to cut that bolt out.
Good point and info
- jor
My 68 has the aux tank. The left forward bolt is a phillips type. I got it out by using one of those manual impact tools that you smack with a heavy hammer. It's an Arizona truck though and wasn't rusted badly.
jor
jor
- 1971ford
- AustinTom
Re: re: how to access a bed bolt
now is that really just a screw driver or is there actually such a tooljor wrote:one of those manual impact tools that you smack with a heavy hammer.
- rjewkes
sounds like cold chizels.
fuelly.com
fuelly.com
its called a impact driver. it has removeable bits you can put in it. it is designed to turn when you hit it hard enoough. they do work on most things you can get them on or into.AustinTom wrote:now is that really just a screw driver or is there actually such a tooljor wrote:one of those manual impact tools that you smack with a heavy hammer.
- rjewkes
also if you go just big enough to fill the center of the head of the bolt with a good drill and bit you can get it out or even cold chizel it from the bottom sound. never melt it from the top don't ask how i know.
fuelly.com
fuelly.com
Just drilling (or grinding) the head away will accomplish nothing. The rest of the bolt will still be held captive by the J-nut.
Just buy (or borrow) a small angle grinder and put a cut-off wheel in it...it'll make short work of the bolt. Of course, I'd try the PB Blaster route first...you might get lucky.
- 1971ford
