bed liner or paint?
what should i use?
Total votes: 0
bugser
re: bed liner or paint?
Post by bugser »
For the life of me I can't remember what my dad used in the bed of his S-10. It came in a gallon can and he rolled it on. Been there for 5 years.
RON
Excuse me while I whip this out
Tim P.
Post by Tim P. »
SEM has a better product I have seen the duplicolor peel off before the sem I have used twice and never had a problem with it better than herkliner cost me $180 for everything+ $20 for the gun to sprayit
basketcase0302
Post by basketcase0302 »
I voted for the spray-on. Hope to someday soon get this done to my Ranchero. :D
Though I don't have any expierence with any of them.
Basketcase
kl1lt
Post by kl1lt »
I would stay away from a drop-in liner. Water can get between the liner and the bed and start to rust it. The liner will move and scratch the paint then that water will set there. :2cents: With the availabilty of all these DIY spray-on and roll-on liners I would go that route. Luckily my truck came with the "30 year dirt and grime" bed liner. Good luck.
Joe
SOOW
RedneckTexan
Re: re: bed liner or paint?
Post by RedneckTexan »
kl1lt wrote:I would stay away from a drop-in liner. Water can get between the liner and the bed and start to rust it. The liner will move and scratch the paint then that water will set there. :2cents: With the availabilty of all these DIY spray-on and roll-on liners I would go that route. Luckily my truck came with the "30 year dirt and grime" bed liner. Good luck.
:yt: I strongly agree with this. Just ask maxklinger about his 83 f-100. I vote spray-on liner :thup:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
1971ford
Post by 1971ford »
ok, i think i have decided on dupiliner. do they have a website or anything? i couldnt find any info on them.
thanks for all the help!
-Ryan
the parts store carries hurculiner maybe dupiliner also.
theskytoucher
Post by theskytoucher »
Walmart carries dupiliner! the one gallon kit was like $89
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1971ford
Post by 1971ford »
can anyone estimate on how much i will need?
i have a long bed styleside
-Ryan
pollock
Post by pollock »
1971ford wrote:can anyone estimate on how much i will need?
I just put Herculiner on my truck 2 weeks ago. The base kit includes a gallon. For a longbed, they sell an additional quart, which you will definitely need. I used all but a few ounces.
The kit includes a roller handle, two rough foam rollers, a brush, and one scotch brite pad. The one scotch brite is not remotely adequate. What you need for surface prep depends on what kind of surface you're starting with.
I had already recently done some surface-rust treating and plain spray painting in my bed, so I was starting with a pretty clean surface. Still, I fired up my DA sander and blew through a handful of 180-grit pads. Then used about 4 scotch brite pads in the tighter spots.
The kit recommends acetone or MEK for cleanup, or as a thinner if needed. You can buy a quart of acetone at autozone for under $10. You need it.
You really need to plan on 2 consecutive days to do this. Prep will take probably 3-6 hours depending on the condition of your truck and what kind of equipment you have. It will take 1-2 hours to apply the first coat. Let it dry overnight and apply the second coat.
Fumes were pretty strong. I did it out in my driveway with a fan blowing the first day, and decided to wear my respirator the second day.
EDIT: Oh yeah, spring for a box of disposable rubber gloves. This stuff is nasty. Washing your hands with acetone is probably not something most dermatologists would recommend.
1971ford
Post by 1971ford »
cool thanks for the info!
luckily my bed isnt that bad. it has few surface rust spots. and my dad actually just brough home a box of about 30 pairs of gloves from work. the boss told him to throw them away because they were faded so my dad grabbed them.
-Ryan
MaxKlinger
Post by MaxKlinger »
Hahaha I was going to bring that up, but you beat me to it! I wish I had a picture of the bed on my '83. The floor was almost completely gone, the drop-in liner and and a few sheets of plywood were doing most of the work! kl1lt is absolutely correct. You'd be better off doing nothing than putting a drop in bedliner on.
I'm probably going to get a spray-in for my '72 when I get to that point.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
1971ford
Post by 1971ford »
i might look around and check herculiner or dupliliner out. maybe even buy some although i dont plan on applying it until next summer.
-Ryan
cghstrojan08
Post by cghstrojan08 »
I used that spray paint stuff from advance auto and then I put a drop in bed liner in just because I like them better.
ROBERT
Member #1076
1968 F100 SWB 360
