Cleaning Frame!
Cleaning Frame!
Hello All,
I recently had a friend of mine come over to give me tips on restoring my 71 custom F100. I'm getting the frame ready for painting soon. He told me to get some oven cleaner and clean the frame with it before anything. He said it works better than anything period! He believes in this stuff so much he buys it by the case. He said that degreaser has nothing on this stuff. He said it would even take paint off. I was wondering if anybody has tried this. I haven't had the time because of working too much lately. I think I will us it under the cab and frame. Also cleaning the transmission just to name a few.
Larry
Larry
- Wes
Yeah it works. there used to be an engine cleaner on the market that i suspect was oven cleaner relabeled. I forget the the name but it was Foam something.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
re: Cleaning Frame!
oven cleaner is wicked cleaner, you still may have to agitate with something though, but you better be ready to paint if you remove all your old grease and paint, it'll surface rust (flash) fast.
Georgia71 wrote:I heard you have to be careful with this stuff because it's got lye in it. I think I'll pick up some this week.
Larry
and you need to be careful around the wires...some of that stuff will clean right thru the insulation
- kaptnkaos
re: Cleaning Frame!
hmmmm...
When reading this post about oven cleaner having lye in it, made me wonder if it would also work to remove the annodization (?) from the brite trim and grille?
That might be worth doing a little experimenting with...
it would certainly make stripping it easier.
KaptnKA
S
KaptnKA
- hardtailjohn
re: Cleaning Frame!
Yep, it works for all of the above...it'll get through that old tough caked on grease like nothing else...we use it on steam engines.... and it will take the anodizing off the brightwork.
JH
JH
re: Cleaning Frame!
Interesting to know. Any particular brand that seems to work better than the other?
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
- The Good Humor Man
re: Cleaning Frame!
I use to use Easy Off oven cleaner to take off old door lettering on used trucks would buy.
You have to be careful, some repaints it would take off the paint, but most original paint jobs there was no problem with.
If you try this test it somewhere like a inside of the door first to make sure that it doesn't take off the paint.
http://WWW.GoodHumorTrucks.Com
re: Cleaning Frame!
Hi All,
Well I'm going to try to post a before and after picture. Hopefully this will work!
Larry
Larry
- 72stepside
re: Cleaning Frame!
Nice and clean.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Hedman Headers
Disc Brakes
- Whoaaanelly
re: Cleaning Frame!
Yeah, I did that on mine as well. Worked just like it did for you. I took a little wire brush and worked in a little before I hosed it off and I didn't have any paint left to contend with afterward either. The fun part was digging out all the old gross oily/tar like crud and debris from the front cross-member.
Roger
____________
07 Ford Escape Limited (first new car ever)
78 F350 Flatbed (Dentside)
67 F100 Pickup (Bumpside)
65 Falcon 2-door Wagon
63 Falcon Ranchero
____________
63 Falcon Ranchero
- JWW
re: Cleaning Frame!
Can you use the oven cleaner on the engine??
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
