I keep seeing ebay listings stating that the 390 is a big block. I also see postings from people on this site saying that a 360 is the same block as the 390. I've had chevrolets all my life....my last truck was a 454 big block and it looked (valve covers anyway) larger than a chev. 350's valve covers. My 360 Ford reminds me of the chevrolet 350 small block in the looks dept; but, I know that Chev. used to have a 396 big block ...so anyway my question once again is, is my ford 360 a small block or big block.
Thanks....and pardon my ignorance.
Is a 360 a big block or small block????
- 71Ford
http://www.fordification.com/galleries/ ... p?pos=-851
71 XLT RANGER ->203,000+MILES/NOT REBUILT
99 GMC 4x4 Suburban, 94 Saturn 200k, 03 Chev Venture
- cobraF100
re: Is a 360 a big block or small block????
The FE is a "Wide Block".... about the same weight as the 350 around 650lbs complete with all the add on's
Chris
Never Forget Our Soldiers
- 68F250
360 is a big block, so is the 352 and the 332. They are all basically the same blocks with different cores.
Same deal with the chevy 400, it's a small block right?
- DuckRyder
It is really neither.
It is an FE. It is kind of like the 348/409 chevy of the ford world.
When most people refer to a Big Block Ford they mean a 385 series LIMA (429/460) A small block they usually mean a Windsor (302/289/351) Ford also made the Cleveland, Y block and FE/FT series.
If you are trying to clasify it, it is a big block, but if you are buying stuff you are alot safer to call it an FE!
- ak-1970-360
What makes a small block a small block and what makes a big block a big block? in other words how do you decifer wheather a new motor is a small or big block?
I'm not certian but I think the "bigblock" term came out when chevy started making their larger series engines instead of just the 283/327/350 size.
just as a funny... I always refered to the FE ford as a FAT ENGINE
and a darn good reliable powerplant too!
they have the charicteristics of a big block in size, weight, and use, but
I just tend to think of them as a FE and it saves the confusion with the 429/460 as they are bigger in the cubic inch displacement department.
I guess I've always thought of the 429/460 engines AND the FE engines as big blocks, and the 289/302/351W and 351C/400M as small blocks.
- customcrewcab
i aways say fe stands for f#%ing enormous
thats good!
yeah I geuss the FE is pretty much a bigblock since they were the bigger option in the cars of the sixties ie: opting for the 390 instead of a 289.
I stand corrected,
Keith is right... especialy when you do the math and
a 428 has more actual cubic inches than a 429!
