Whats the easiest way to remove the bed?
Ranchero50
Post by Ranchero50 »
Getting ready to do the diesel swap in the F-250 and want the bed gone so I can flip the cab back for some rust repairs and to get it out of the way as well. I pulled the plastic bed liner out last night and saw the carriage bolts (and some rust in the bed...) I'm trying to figure out how the lift it off the frame in one peice without screwing it up.
I'm considering rigging it off the frame with a chain fall via some 2x4's placed under the bed rail. Is there an easier way? I can lower it onto a big dolly that I refinished my farm tractor on to roll it out of the way.
Thanks in advance.
Jamie
JWW
re: Whats the easiest way to remove the bed?
Post by JWW »
The way I did it once I removed the bolts was lift it off with my dad's help. However, it would have been easier with a couple more people. Once you get over the tires, it will slide right off.
Remember, there are two bolts that you can't see near the bumper. I didn't realize that until I tried to lift the bed off.
Good luck. :thup:
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
ima71 trucks are older
Post by ima71 trucks are older »
weld up a "X" out of 2" angle iron, square tubing, pipe, what ever you got laying around long enough to fit under the lip of the bed rails. hook a chain in the middle and lift it off with an engine crane. drive truck out from under it.
15 minute job if you just torch the nuts off the bed bolts. :thup:
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
Ranchero50
Ima71, thanks that makes the most sense since I'll be doing it solo.
BTW, Ima71 too
Jamie
MaxKlinger
Post by MaxKlinger »
Watch out with those plastic bed liners, they're bad news. They trap water underneath and rub the steel of the bed when they vibrate, the perfect recipe for rust. I wish I had pictures of the bed in my '83, there was only about 15% of the floor left for that very reason.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
MadMaxetc
Post by MadMaxetc »
You can Remove the bed from the Cab by cutting the frame and all the lines (including the drive shaft) between the Cab and the Bed.
ohhh...was that not what you ment??? :D
8 bolts to the frame and one electric plug. 2 Guys can lift it off, but 4 is better. 1 guy with a few 2x4s as rails could slide it off the back.
Dan
FORD Girl
Photobucket Pictures
RedneckTexan
Post by RedneckTexan »
MadMaxetc wrote:You can Remove the bed from the Cab by cutting the frame and all the lines (including the drive shaft) between the Cab and the Bed.
:doh: You beat me to it MadMax :lol:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
Ranchero50
Yeah, the liner was in there when I got it and probably not go back in. The floor is in decent shape with some rust above the toolbox and the normal two holes where the front diagonal braces weld on.
Jamie
BobbyFord
Post by BobbyFord »
ima71 trucks are older wrote:weld up a "X" out of 2" angle iron, square tubing, pipe, what ever you got laying around long enough to fit under the lip of the bed rails. hook a chain in the middle and lift it off with an engine crane. drive truck out from under it.
I used a nylon motorcycle tie-down in each corner and my cherry picker. Piece of cake.
Ranchero50
Burned off two nuts, ran out of Oxygen... Maybe tomorow...
Nothing quite so much fun as crawling under a hot truck on a hot sticky day and running a torch...
Jamie
Ranchero50 wrote:Burned off two nuts, ran out of Oxygen... Maybe tomorow...
Jamie
You cant run out of oxygen today its a tuesday. Your regulator must be clogged. You only run out of oxygen after 5pm on a friday . :lol: :lol:
69 F100 300-4spd
78 F150 300-3spdOD
Ranchero50
When you work twelve hour days and home is fifteen miles away you sure can. Hopeefully my buddy will stop by to refill his tanks since I used most of it on his jeep project last week.
Jamie
