body/core support mount question?
rjewkes
Post by rjewkes »
are the 2 wd and 4wd the same parts for the rubber mounts?
while i'm asking this are the core supports specifically the radiator support different or the same?
fuelly.com
rjewkes
Post by rjewkes »
i guess they are was just currious cuase the catologs only sell ones for 2 wheel drive.
fuelly.com
averagef250
Post by averagef250 »
They are different. AFAIK they aren't made for bump 4x4.s. The core supports are different 2wd/4x4.
re: body/core support mount question?
You can use a 2WD support on a 4x4 as long as you also use a 2WD radiator. The rubber bushings are the same.
rjewkes
Post by rjewkes »
ok thanks guys. just trying to figure it out.
fuelly.com
mljjones67
Post by mljjones67 »
Whats the best way to get the core support off? I have the nut off of it. But it wont come off. Do I need a big crow bar??
If you have the nut off the bolt, the support is loose, and should just lift straight up. However, if the bolt has rusted to the bushing's inner shell, you might find it easier to just fire up the cut-off wheel and slice through the bushing and bolt, since they'll be replaced anyway. I've had to do that with several parts trucks.
