Stopping rust
mljjones67
Stopping rust
Post by mljjones67 »
Ok guys I started tearing the front off this week and I ran into some pretty nasty rust issues. Question what is the best product out there to kill rust? I want it stopped so I can weld some pieces back on to get the strength back.
Here are the pics
This one is on the drivers side. There was 6 inches of very fine dirt in there.
Here is the inside same side.
Passenger side
MadMaxetc
Post by MadMaxetc »
You remember the show Full House?
As Joey used to say "Cut it out!"
sorry, I have tried many differant things and Metal=ready from POR-15 is the only stuff that I have used that works. Some say Oshro (or something like that) work. I can not get it around here, so I don't know for sure.
Dan
FORD Girl
Photobucket Pictures
Supermike
Post by Supermike »
I thought I would never see someone quoting "Full House" on a Ford truck website.
The apocolypse has arrived. :lol:
Mike, it looks like you've got your work cut out for you... literally.
layedout72
re: Stopping rust
Post by layedout72 »
looks like a ton of patching! just remember....work from the outside in. start at the places that help allign things!
Supermike
Post by Supermike »
You might also consider Rust-bullet... unlike Por-15, it can be sprayed. THere was one guy on this site that's used it and said it worked well, but it would be a good choice for treating those areas you might not be able to reach very well.
mljjones67
re: Stopping rust
Thanks Mike I have been looking at there site. Seems like a good product. Have you used it yet??
Banjo
re: Stopping rust
Post by Banjo »
Depends on what you want to do with truck in long run. As bad as that looks, I'd think seriously about sandblaster, cutting out, welding in and sealing new metal with something. When drain areas get plugged with leaves/sticks, they'll build up dams and hold dirt/silt/water and rust starts from inside out. I'd also go along whole truck right now and look for plugged drains.
Banjo
re: Stopping rust
Post by Banjo »
just relooked at your pix, I would definately consider sandblast before anything, because you probably have adjoining areas that'll either blow out due to sandblaster or welder (get's thin). Then weld in good metal and either epoxy prime whole repaired area or seal in some fashion. I coated new floorpans with POR-15 as an added precaution and that was after sandblast. But, I am very paranoid about every speck of rust.
Supermike
Re: re: Stopping rust
Post by Supermike »
mljjones67 wrote:Thanks Mike I have been looking at there site. Seems like a good product. Have you used it yet??
Not yet... I want to order some for my bumper and to treat one of my inner fenders (around the battery tray), but I've been too lazy to order it. It's on my list, though...
Banjo
re: Stopping rust
Post by Banjo »
I thought of something else for you too. You need to check where your leaks are coming from and I found my wiper transmissions were leaky and had to unbolt those and reseal, because they run right through the cowl. You might check these and windshield gasket too, just a thought, have a good one, Banjo.
rjewkes
Post by rjewkes »
depending on the amount of rust, and the availabilty of a cab.
fuelly.com
REID
re: Stopping rust
Post by REID »
i am restoring a 72 ford truck, not as bad as yours, but i used a product calle Chassis Saver. I painted the entire underside with this and it can be painted over with any color. very pleased thus far, can be ordered by mail--79.95 a gallon plus shipping.
check it out at magnetpaints.com
reid
