I finally found time to remove the cab from my '69 project and strip it down. In the process, I found that the drip rail had some rust and even a few of holes. The only place where it is actually separated from the roof is about an eight-inch place on the passenger side. I checked out Keith's pics on his project but I didn't think my cab was in quite as bad of shape as his. I have only ran a wire brush across the drip rail and I'm posting pics of what I found. (I didn't have the air compressor in the garage or I would have blown the dust out.) I would like your opinions and ideas for how to best repair if you think I could fix it without replacing the whole cab. The rust you see is the only holes in the cab. The floor pans are perfect. Thanks in advance!
Monty
P.S. and Yes, I see that the date on my camera needs to be set!
http://home.ec.rr.com/emontgomery/Image ... %20136.jpg
http://home.ec.rr.com/emontgomery/Image ... %20137.jpg
http://home.ec.rr.com/emontgomery/Image ... %20138.jpg
http://home.ec.rr.com/emontgomery/Image ... %20139.jpg
http://home.ec.rr.com/emontgomery/Image ... %20141.jpg
http://home.ec.rr.com/emontgomery/Image ... %20142.jpg
http://home.ec.rr.com/emontgomery/Image ... %20143.jpg
