How do you install a rear window?
cghstrojan08
Post by cghstrojan08 »
I need help to install my new rear window. I have heard something about using a rope?
ROBERT
Member #1076
1968 F100 SWB 360
Wes
Post by Wes »
nylon cord @ 1/8 dia. you put the rubber on the truck, wax the cord lay in the rubber channel all the way around set the glass in on top of cord pull cord, lip of rubber will be pulled around glass.
Wes
67 F250 High boy
69 Bronco
foghorn
re: How do you install a rear window?
Post by foghorn »
Wes must have dislexia. try puitting the gasket on the glass take your finger and run the rope in the groove for the pinchweld. Get a helper and set the window in the opening bottom first. Your rope should start and end in the middle at the bottom. I like to use a lil gojo to slick the rubber up some this also cleans off real easy. Have your helper just hold the glass in place with lite pressure. Take one end of the rope and pull the rubber over the lip till you get about half way up the side. Then take the other end and do the same but go just past the top corner. Also at the corners pull the rope in a circcular motion so as not to cut the rubber. Once you get the other end just past the top corner go back to the other end and work it past the top corner also. At this point i like to pull both ends at the same time as some times it has a tendency to slide in the rubber. Once you have the rope all the way out take the palm of your hand and pat it the rest of the way in sometimes they dont get seated in fully till you do this. If you have any rubber that looks like it still could come in more try taking your fingers and putting themon top of the rubber next to the glass and pull down and in all in one motion. Kinda like getting a finger hold on a climbing wall. I hope this helps you If you have any questions just pm me your number as i have nation local calling and can explain better on the phone.
Foggy 8)
