Bed Flex
greenbank
Bed Flex
Post by greenbank »
Just curious if what Goldie does is normal or not. If I load up the bed of my truck with a lot of weight on one side, I get pretty good deflection in that direction. For example, the bed and cab are nicely level with each other then the bed is empty; I had a 900 lb engine/tranny combo in the bed lashed to the passenger side and the bed was down a good two inches from level, then. Is this the bed flexing? The frame? Is it normal?
There's no rust in my truck and I went underneath today to poke around and the frame looks pretty good, no cracks as far as I can tell.
I just don't want to stress something before fixing it if this doesn't sound normal to you guys. I have to haul an engine/tranny/front end/rear axle/wheels tomorrow so I can take a couple of pictures with it all loaded up.
1968 F250 Ranger Camper Special
-- 360, AT, PS, PB, disks
-- See Goldie
averagef250
Post by averagef250 »
Sounds normal to me. Best to put the load in the center over the axle if possible.
Thunderfoot
re: Bed Flex
Post by Thunderfoot »
Pretty normal,
As Dustin said, try to center your load in the bed as much as possible. :wink:
Shayne
rjewkes
Post by rjewkes »
yep, the 4x4 realy flex over uneven terrain. I think the frame and bed have a certain degree of give built in to them.
fuelly.com
xxxtina63
re: Bed Flex
Post by xxxtina63 »
Sounds about right. Frame should twist a little to compensate for load.
greenbank
Post by greenbank »
Thanks for the replies. Which begs the question...what happens when you do the same thing in a unibody?
-- See Goldie
QC
Post by QC »
That's probably why they only made unibodies for 2 years.
69 F-100 Ranger 302
mjhaltom
re: Bed Flex
Post by mjhaltom »
CRRRAAACCCKKKK!!!!!!
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
foghorn
Post by foghorn »
QC wrote:That's probably why they only made unibodies for 2 years.
HMMMM i always thought it was just one year for the unibody truck but i maybe wrong
Foggy 8)
