Cab Mount Questions
gonzalo medina
Cab Mount Questions
Post by gonzalo medina »
Are the front two cab mounts bigger then the back two? All four almost look identical. Don't want this thing uneven.
re: Cab Mount Questions
The front two cab mounts are separate pieces. The rear mounts are actually just bolt-holes in the cab crossmember that bolts to a frame crossmember....they aren't separate pieces. Sounds like you've got two pairs of front mounts?
gonzalo medina
Sorry...I was referring to the rubber bushings. I bought a kit for the whole body and there not labeled.
Here's a picture of a comparison between the factory rear cab bushings and a set of replacements bought from LMC. IIRC the front bushings didn't have the vertical indentations along the sides.
merclover
Post by merclover »
so do you think its a bad idea to just make front mounts? cause i just cut to old bolt out, replaced it with a new bolt with a plate metal washer on top and im gunna just make cab mounts with some thick sheet mail
68 mercury m-100 brand new 390/c6
mrsnicks
Post by mrsnicks »
Merclover...
Are you talking about MOUNTS or BUSHINGS?
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
merclover
Post by merclover »
mounts
1971fordcustom
Post by 1971fordcustom »
Im glad you put the photo on there. I wont go to lmc for that part ive had good parts from them and really bad parts lol.
