Body Mounts
RTG_RACING
Body Mounts
Post by RTG_RACING »
Anyone have any good ideas on how to replace the rubber body mounts without taking the cab off of the frame? I can get the bolts out but can't get the mount to seperate. Do they screw togeather? Thanks in advance.
marz68
Post by marz68 »
They don't screw together it's just that their welded together with rust. lol If your going to replace them then I would torch, sawsall or hacksaw them off.
good luck!
GT-Racer
Post by GT-Racer »
where's the best place to buy new mounts, has anyone had good or bad experiences with them?
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
GT-Racer wrote:where's the best place to buy new mounts, has anyone had good or bad experiences with them?
Mounts or bushings? For the mounts, I'd definitely spend the few extra $$$ and get the Dennis Carpenter repops. They're much stronger than the stamped steel versions, and still have the factory appearance.
I got both the front cab bushings and radiator support bushings from LMC, and while the bushings themselves are fine and will work, the bolt they supply with each is threaded wrong. One was too long overall and the other wasn't threaded up far enough. Here's a comparison of the LMC pieces and the stock factory pieces:
GT-Racer
Post by GT-Racer »
Thanks keith. Did you just replace the bolts with your own from a hardware store?
re: Body Mounts
Nah, I just reused the factory bolts. Since I'd parted out several trucks I was able to assemble a full set of bolts that weren't totally rusted or stripped out.
merclover
Post by merclover »
so yay er nay on making ur own cab mounts?
68 mercury m-100 brand new 390/c6
merclover
Re: Body Mounts
Post by merclover »
"Anyone have any good ideas on how to replace the rubber body mounts without taking the cab off of the frame? I can get the bolts out but can't get the mount to seperate. Do they screw togeather? Thanks in advance."--------- i just jacked up the side of my cab and put some new hardware in im not sure if it'll work for you but i worked for me
Wes
re: Body Mounts
Post by Wes »
you'll have to lift it some, maybe block it up a little w/ some wood.
Wes
67 F250 High boy
69 Bronco
merclover
Post by merclover »
has anyone ever made there own cab mounts, if so n e tips im doing mine right now but other than keeping the cab level is there anything i should do?
