67-69 hood letter removal ???
kaptnkaos
Post by kaptnkaos »
Hey all,
I picked up a pretty decent fairly rust free hood to replace the rusted out one on Olde Skool. What's the best way to remove the 67-69 hood letters without damage ??? The letters are in nearly mint condition, and I don't wanna damage them.
thank you,
KaptnKAOS
Heavenlyfire
re: 67-69 hood letter removal ???
Post by Heavenlyfire »
If it is the same as my 71, you just unscrew the nut on the backside and LIGHTLY tap them out.
mrsnicks
Post by mrsnicks »
The actual letters on the front don't have a nut on the back I don't think.. the side hood markers do, but not the F O R D letters.... there are 2-3 pins on each letter, the slide into a bushing on the hood.
Tap the pins from the backside with a hammer or punch a little at a time on each pin so the come out even.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
kaptnkaos
Post by kaptnkaos »
mrsnicks...
You are right the 67-69 hood letters do not have nuts like the later 70-72 have. They look like they have a cone shaped piece that fits over the pins on the inside of the hood. If I hammer then out, will I be able to reuse them ?
I parted out a '71 CS and it just had the half nuts with neoprene inserts like the side markers.
Thanks,
KaptnKAOS
mrsnicks
Post by mrsnicks »
If there are cones/nuts/caps covering the pins gently remove them with pliers, either by twisting them or pulling on them. (not quite sure how they come out).
If you are careful and gentle, then yes, you can reuse them.
Patrick
Chevrolet
jor
Post by jor »
Here's a couple of photos. The blue one is factory and the red, a reasonable facsimile.
jor
ezernut9mm
Post by ezernut9mm »
i used the same thing as you jor. i found my hood letters in the glove box so i went to o'reilly auto and bought two packs of the above clips and used them to secure the letters.
kaptnkaos
Post by kaptnkaos »
Hey Guys...
Thanks for your replies..
I got the letters of this evening with out any problem. They had the kind like in the blue photo. I tapped the loose with a brad hammer until I could get a small screwdriver blade under the letter a gently pryed them up some of the clips came out attached to the pins.
ezernut9mm.. you mentioned gwetting those clips at o'reilly auto parts.. I imgine that about any auto parts house would have them? I can't think of where there is an O'Reilly's around here.
thanks again...
KaptnKAOS
rjewkes
Post by rjewkes »
jamb nuts or ami thinking of something else? Also available at any farm/home supply or hardware stores in diff sizes.
fuelly.com
