"Soft weld" wire for MIG??
snake
Post by snake »
Sorry guys, I know I've seen this in a couple posts not all that long ago and I did do a search but came up empty .....
What is that special wire called for MIG welding patch panels that results in a softer weld that's easier to grind??
Thanks in advance!!!
hardtailjohn
re: "Soft weld" wire for MIG??
Post by hardtailjohn »
Snake,
You might do a search over on metalmeet.com .... there's alot of info on that over there.
Good luck!
JH
indy358
Post by indy358 »
You want to use a 70S6 wire. It has a higher silicon content which makes it easier to work with. It flows better in the welding process and it is easier to grind.
Also you might want to try using a gas mix with a little oxygen in it. The Oxygen makes the arc a little hotter so you can use a higher travel speed and not heat soak the thin metal as much. I use a mix of 88% Argon, 10% CO2, and 2% Oxygen. Most gas companys don't have this exact mix but if you can find something with under 5% Oxygen you should be ok.
Jayson
94 Cobra convertible Pace Car 300hp 302FI
07 Shelby GT 325hp 4.6L
58 Fairlane 292 Y-Block
65 Mustang 271hp 289
05 Excursion 4X4 XLT 6.0L
10 Camaro 1LT RS (wife's car)
76 Chevy Scottsdale 3/4 ton 4X4 350
