Billet grille?
mustango
Billet grille?
Post by mustango »
You guys know of a company that makes a good grill or custom billet grille to replace the bent one on my '71?
Mark C.
'71 F-100 LB, FE 390.
I was thinking of the immortal words of Socrates who once said, "I drank what?" (Val Kilmer in Real Genius)
re: Billet grille?
To the best of my knowledge there isn't any aftermarket companies reproducing the '71 grille inserts, either as custom (billet) or stock reproduction. Dennis-Carpenter.com sells the '72 inserts, which will fit your '71 grille shell, but of course they wouldn't be correct. Otherwise, I'd just keep an eye on E-bay. Those come through there at the rate of probably 2-3 times/month. Doesn't seem to be any currently listed, but they'll turn up.
mustango
re: Billet grille?
Post by mustango »
So I guess most old ford truck guys would find a slightly bent grill on a restored truck acceptable. :)
Mark C.
cobraF100
re: Billet grille?
Post by cobraF100 »
customcrewcab, Has made a set of Billet inserts for his Truck,you may want to ask him..
Here's a Pic of what he did:
Link to his post:
http://www.fordification.com/forum/viewtopic.php?t=1878
Chris
Never Forget Our Soldiers
re: Billet grille?
Just as a point of Clarification.
71-72 Grill shells are the same and D-C reproduces those. This is the large alum part that the inserts and head light bezels screw to. (And the part that would bend along with the HL bezels) The inserts are plastic AFAIK and wouldn't "bend".
The inserts are available for 70 and 72. One would assume that the 71 ones might be along at some point.
HTH
1968_ONEHUN
re: Billet grille?
Post by 1968_ONEHUN »
well done looks REAL NICE. :evil:
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
mustango
re: Billet grille?
Post by mustango »
My inserts are ok, it's the aluminum part that's bent.
Mark C.
re: Billet grille?
Oh, I misunderstood...I thought you were looking for the inserts, not the grille shell. Yes, THOSE are available aftermarket from Dennis-Carpenter.com, as DuckRyder mentioned. Kinda pricey at $375, but I suppose worth it to some people.
