Need to remove painted on lettering
69CSF250
Post by 69CSF250 »
I bought a fire truck the otherday and would like to know if anybody knows of a good way to remove the painted on lettering?
rjewkes
Post by rjewkes »
if iuts vinal a hair dryer and a carpet knife blade. Heat iot up by waving the dryer on low or medium and try peeling it back by hand if it won't come try uising the knife to cut the glue.
If paint then a water soaked 000(tripple ouight) steel wool might just ontop of the lettering.
fuelly.com
mrsnicks
Post by mrsnicks »
They also make a rubber attachment for your drill, that will remove vinyl lettering. It's about a 6" round, rubber circle, with a post in the middle for you to attach to your drill.
You run it and use the beveled outside edge to remove the vinyl stickers.
I don't know if it has a "proper" name. We had one at a place I worked.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
mljjones67
re: Need to remove painted on lettering
Post by mljjones67 »
Does it have a clearcoat over it?
71 LONG BED
Post by 71 LONG BED »
I have used Easy Off oven cleaner a few times and it works pretty good. You'll need a lot of elbow greese too! :o Nice truck BTW!
John Member #1549
Image Image Image
CA180
Post by CA180 »
^ Two votes for oven cleaner
69CSF250
Post by 69CSF250 »
Thanks for the info the lettering appears to be clearcoted not sure though and I think I will try the easy off oven cleaner will this damage the paint around or under the lettering? I suppose I would do this very sparingly and rinse well after each application? if that works would then wash and wax the affected area? If you cannot tell I am very nervous about messing up the paint job it looks remarkably good for as old as it is... I will post more pictures soon... I very much appreciate the help!!!
69CSF250
Post by 69CSF250 »
If its not clear coated should I assume that it is clearcoated under the painted on lettering I would think that it is most likely? Thank god for this site! ON a side note anyone have any idea what the tank and pump with 200feet of hose would be worth I don't plan on keeping that stuff? Thanks guys!!!
wt4speed#2
Re: re: Need to remove painted on lettering
Post by wt4speed#2 »
69CSF250 wrote:ON a side note anyone have any idea what the tank and pump with 200feet of hose would be worth I don't plan on keeping that stuff? Thanks guys!!!
Find a Volunteer dept donate the pump and hose and reel and ask for a receipt for the items and use as a tax deduction .
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
71 LONG BED
69CSF250 wrote:...will this damage the paint around or under the lettering? I suppose I would do this very sparingly and rinse well after each application? if that works would then wash and wax the affected area? If you cannot tell I am very nervous about messing up the paint job it looks remarkably good for as old as it is... I will post more pictures soon... I very much appreciate the help!!!
I had to remove some DOT numbers on the '67dump. I didn't care about the paint and went at it with Easy Off and a Scotch Brite pad. You can barely tell it got scratched! My point is, the paint on the body is pretty darn durable. The oven cleaner takes the lettering off pretty well and doesn't effect the paint. One thing to note, you may still be able to see were the letters were after all the paint is removed. If the truck was stored indoors, which it looks like it has, there probably wasn't much fadding, but old paint jobs show where the lettering used to be.
John Member #1549
Image Image Image
ezernut9mm
Post by ezernut9mm »
i'd drive it as is. lol (seriously).
jzjames
Post by jzjames »
carefully rub it off w/ laquer thinner on a rag. Dont rub through the base paint. It will take some time, but youve got plenty of that :D
foghorn
Post by foghorn »
jzjames wrote:carefully rub it off w/ laquer thinner on a rag. Dont rub through the base paint. It will take some time, but youve got plenty of that :D
No dont use this use dupont 3812 if it is sign paint it will remove it safe enough.
Foggy 8)
69CSF250
Post by 69CSF250 »
Thanks for the info as soon as the weather breaks and I get some time I think I am going to work on removing the letters... My dad thinks I should keep all that on the truck but It just does'nt feel like my truck with someone else's writing on it... Good idea about donating the pump and tank too. I will let you all know how it goes thanks again...
71 LONG BED
Don't forget to post after pics.... :wink:
John Member #1549
Image Image Image
