Can you use POR over body filler or does it have to be clean metal? I know you dont have to sand all the rust off just the scale that is why I am asking. I though about totally smothing my frame with a little body filler, but this eliminates powder coating as it wouldnt stick and if it did , the filler would probably bake out.
So would POR 15 work better in this case?
I know beat the dead horse....POR15 question.
- GT-Racer
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....![Smile :)](./images/smilies/icon_smile.gif)
re: I know beat the dead horse....POR15 question.
I don't think they've specifically mentioned anything about body filler on their website, but I don't see why that would cause any problems, as long as the filler isn't super-smooth. Rough it up a bit to give the POR something to bite into and I'd think you'd be OK. It sticks to everything else (except smooth plastic) like Superglue, so I see no reason why body filler would be an exception.
Whoops....guess they DO mention it, but they say to put the filler material on top of the POR-15, not under it. From the POR-15 Application Information:
CAN I USE BODY PUTTY OR FILLER WITH POR-15?
Yes. First paint both sides of the rusted area with POR-15; then use body filler or putty as soon as the POR-15 is dry to the touch. For best results and adhesion use our StraightLine or RestoGrip body fillers over POR-15.
- GT-Racer
Remember por15 is basically a thick epoxy.... I am almost positive it works the same as your epoxy primers as far as what can and can't be done.
If it can hold it on the truck, I don't see why it couldn't hold it against the truck. Why would it matter what side the por-15 is on? Ya know?
I agree...I've gotton this POR-15 on all kinds of stuff (most accidentally) and rest assured that it will NOT easily come off. Even though the company would prefer you to put it OVER the POR-15 (just to make sure the metal is protected), I see no reason why you couldn't do the filler first and then cover it with the POR. I would think that as long as the metal prep was correct and the filler sticks to the steel, the POR isn't going to have any problems sticking to the filler.
- jzjames
do you think Por15 is like epoxy or is it like a urethane (i.e.; cures in a moisture environment)? When I used the Por15 out of the tube, I noticed it bubbled a bit as it cured much like urethane glue does.
I am (almost) positive it IS an epoxy product.
