Some patching questions
wt4speed#2
Post by wt4speed#2 »
I'm considering using fiberglass to patch some areas that are just too thin to weld due to rust problems. This is probably the bone headed question I ever posed. Will fiberglass adhere to steel?
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
re: Some patching questions
Yes, it'll adhere and work just fine, as long as you properly prep the surface.
wt4speed#2
I knew I could count on you "Dad". You know I've always thought of you as a fatherly figure...just not mine :D , You've got enough troubles
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
