14 U- JOINTS
14 U- JOINTS
I have got 14 u-joints on my 72 4x4 bump. Anyone care to guess where they all go?
Engage Brain BEFORE Engaging Gears
72 F-250 390, NP435, Dana 24, D60, 14b, 4.88s, detroits, 2 winches, 4x4 40" tires.
- 72hiboy4x4
front axle (2)
front driveshaft (2)
middle driveshaft (2)
rear driveshaft (3)
PTO driveshafts (5)
did I win?
rear driveshaft (3)
PTO driveshafts (5)
did I win?
re: 14 U- JOINTS
Close but no cigar.
Anyone else?
- crash_552
re: 14 U- JOINTS
is it all factory?
- crash_552
re: 14 U- JOINTS
tranny to transfer -4
transfer to rear -4
transfer to front -4
2 on front axle
transfer to rear -4
2 on front axle
- 71PA_Highboy
re: 14 U- JOINTS
front axle (2)
front driveshaft (3)
rear driveshaft (3)
PTO driveshafts (2)
Steering column (2)
Unless you have a rear steer setup... How stock is this rig?
Eric
rear driveshaft (3)
PTO driveshafts (2)
Steering column (2)
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
re: 14 U- JOINTS
Well you guys are getting close,
2 front axle
2 front driveshaft
2 rear driveshaft
2 middle shaft
4 pto driveshaft
2 steering shaft
2 front axle
2 front driveshaft
2 rear driveshaft
2 middle shaft
4 pto driveshaft
2 steering shaft
- 71 LONG BED
re: 14 U- JOINTS
I'll take one of the PTO u-joints.
Since you have so many.
The one I have that is directly mounted to the PTO itself, is cracked. The PO had a catastrophic PTO shaft failure that riped out the exhaust and spun the shaft in the u-joint and cracked it. The shaft was stuck in the u-joint, so they just torched it off. My dump doesn't dump anymore.
John Member #1549
re: 14 U- JOINTS
Do not flame me too bad,I have a 3 piece chevy driveshaft with 2 carrier bearings. It goes from the 435 to the winch in very back of truck. I took one look at those little pto u-joints and said NO WAY. Mine uses 1310 joints never had a problem.
- 19674x4
yea, with out the PTO you still have 10 like mine
good thing they don't all go out at once. $$$$$$$$$$$$$$$$$$$$$$$
and if you have the open knuckle ad two more
My Photo Album
