wheels
tynall44
wheels
Post by tynall44 »
i got a set of alum. slots for the old truck but they are nasty brake dust bad and just all around cruddy WILL SOMEONE PLEASE TELL ME WHAT I CAN DO TO GET EM CLEAN,,,,,,, :fr: :fr: :fr: :fr: :fr: :fr: :fr:
67F250CS
re: wheels
Post by 67F250CS »
Mothers Blue mag is the miracle cure. Oh a few tubes of elbow grease :lol: You can put a small polishing bit in a variable speed drill and go to town.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
67F250CS
re: wheels
Post by 67F250CS »
Should be at any major auto parts chain in the cleaning section.
http://www.epinions.com/auto-Care-All-T ... y_~reviews
Big D's 69
Post by Big D's 69 »
So long as there not clear coated use acid to clean then up and it will turn them kinda white. THen get on it with some mothers polish or somthing along that lines and use some elbow grease and they will shine like new money. Acid works great, but just don't get it on you.
hillbilly67
re: wheels
Post by hillbilly67 »
and from the trucker in me....run down to the nearest big truck dealer, (insert favorite truck here { } eg. Peterbilt, Kenworth etc,) and get a "sewn cloth" rag wheel, and a brick of green polish. Screw the wheel to your sidegrinder, and let er rip! Been polishin wheels and tanks that way for 20 tears... I mean years!
P.S.-Don't bother goin to mack, they probably don't have any...no point polishin a turd :lol:
Made my first million.....too bad it was mistakes..not dollars! Now pass me that crescent hammer.
ezernut9mm
Re: re: wheels
Post by ezernut9mm »
you're gonna make that bulldog cry if you keep talkin' like that. :lol:
tynall44
re: wheels
Post by tynall44 »
big d what kind of acid :? :? :fr:
trukcrazy
re: wheels
Post by trukcrazy »
This is what I used back in the day. Spray it on, let it set for a few seconds then rinse it off good. It will knock the oxidation, grease and dirt off in a hurry. Then you still have to polish it, but this stuff makes the cleaning a lot easier. Not for clear coated wheels though. http://www.ospho.com/directions.htm Good luck and take before and after shots describing what method you used. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
mljjones67
re: wheels
Post by mljjones67 »
This is what I use. Works really well. I would suggest using one of the acids above to cut the cleaning time down. These also works for dings and gouges. Another recommendation is a very good air compressor that will keep up with the grinder.
If I get a chance I will put a tutorial together.
I can also get a kit together for anyone interested. they run about $55.00 plus shipping. Let me know
Mike
kknip
re: wheels
Post by kknip »
What is the grass clipping on the right for? :lol: The acid is usually called aluminum brite.I have been around trucks since 1987 (paint and bodywork) and the acid will flat clean up some aluminum.That is what I used on my slot rims.I have some polishing compound in the stick form and also some liquid also,but I need to get one of those polishing wheels for the die grinder so my elbows won't run out of grease! :lol:
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
mljjones67
re: wheels
The grass is the special ingredient. It only grows here at my house. It is very expensive so if you need some let me know :D :D :lol: :lol: :lol:
Mike
kknip
re: wheels
Post by kknip »
Does it grow under funny colored lights in aluminum foil lined rooms? J/K :lol:
You knucklehead!
65 Mustang
mljjones67
re: wheels
Well um do do um well ???? Hmmmm I don't know what your talkin about. :D :D :D :P :P :P :thup: :thup:
tynall44
re: wheels
Post by tynall44 »
forget the polish send me that grass 8) 8) 8)
mljjones67
re: wheels
Grass what grass.? :D Mine is still brown from winter?????? :lol: :lol: :lol: :lol: :lol:
