rear of cab trim removal
damraider
Post by damraider »
I did alot of searching with no luck. I know the two short outside corner pieces are bolted but how do the long pcs come off ? Thanks, and great site. Steve.
i'm guessing they use clips that are riveted to the cab. they might just pop off with a screwdriver.
re: rear of cab trim removal
The two outside end pieces have mounting studs that extend through holes drilled in the cab wall, and are held on with nuts. Simply remove the nuts from inside the cab and those two pieces will come right off.
ALL truck side trim pieces are held on with snap-on clips in the middle portions, but the ends are bolted on. You just have to find the mounting studs for the ends and remove the retaining nuts.
Big D's 69
Post by Big D's 69 »
Then once you remove the nuts you can normally put pressure up on the molding or down to relieve pressure off the clips and the molding will come right off.
