is it possible to take the entire front clip off of my truck?
it looks like there's 3 bolts that connect the fenders and inner fenders to the firewall, and then 2 down by the radiator that bolt it to the frame.
can i take the entire clip off if i unbolt all those bolts?
Front clip
- splavin90
Front clip
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- 72hiboy4x4
- splavin90
re: Front clip
is that all the bolts that hold the front clip on?
- 72hiboy4x4
- splavin90
re: Front clip
for the bolt that is under my truck in front of the door, how do i get that one off,
theres a nut and it seems like the whole bolt is just spinning, where can i access the top of that mount?
and-
how many are in the door jamb
and-
the one under the cab for the fenders is a tough one if its spinning. you have to get under there and try to get some vise grips on it. if you cant you might be able to get a sawzall on the head and cut that off. as far as the door jamb there is one bolt per side. it is a short stroke of bolt to remove. i hate that bolt. after the fenders you have the inners bolts and the core support plus the rad and any wiring to get the clip off.
- wt4speed#2
re: Front clip
Don't forget the little fiber pieces from the bottom of the inner fenders to the fire wall .
Tony B
Tony B
