Steering Hard making loud popping sound
I have a 68 F100 manual steering truck. When I make a right hand turn the steering wheel seems to stick and is followed by a loud popping noise and the dashboard even shutter badly. Any suggestions? It is a 3 on the tree.
- bluef250
re: Steering Hard making loud popping sound
Sounds (no pun intended) like your suspension is moving in ways it shouldn't. Check all the front suspension - radius arm bushings, pivot bushings, tie rod ends, steering box, etc. - for wear. Also, check engine and transmission mounts.
- ICEMAN6166
sounds like a bad gearbox to me, being its only on right turns. box may be loose on frame too or the rag joint is getting ready to break.
Thanks for the tipes. Both King Pins shot and the rag joint was bad.
- ICEMAN6166
fix the rag joint and make only left turns until you get the kingpins done.
No not lowered, All stock at this time.
