steering column wiring diagram
rsparks100
Post by rsparks100 »
any help with the wiring diagram for the steering column on my 69 f100.
i put a repair kit in the steering column, that got the right stop light and left front blinker to work. no luck with the others. the tail lights work on both sides as do the front parking lights. help!!!
Ride the Ranger!
bluef250
Post by bluef250 »
Look at this diagram right above the ignition switch:
http://www.fordification.com/images/sch ... _81-85.jpg
What is a repair kit? If this is the cancel lever part, you probably need to replace the switch.
