17s
17s
Anyone running 17s on there truck? I've got a set of 17" wheels and tires, but the tires are way to tall. They hit the bottom of the bed in the rear.
Stock tire shows G78-15, which would be a 235/60-15, the tires on the 17s are 265/70-17. The current tire is 235/70-15... Anyhow, to get to the point, what would be the biggest tire to fit under the bed on a 15 or 17? And what tires are you guys runnin?
- ExplorerNC
What kinda back spacing you got going on? Thats an inche difference between your tires and my 17" tires.
AS for the G78, i was going off of this link.
http://www.turbinecar.com/tires.htm
Shows a couple different sizes for that tire
- ICEMAN6166
re: 17s
tires with letters are passenger car tires.
they are typically load range C.
numbered tires are light truck tires and are load range D and E.
this is the amount of weight each tire is rated to carry.
- theskytoucher
re: 17s
Im running 275/65R15 if that helps at all and i have no clearence issues!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- ezernut9mm
re: 17s
http://www.fordification.com/forum/view ... hp?t=17544
btw, the back spacing is 4" and they barely clear the inner fender well of the box.
re: 17s
I have 285/70-15 BFGs on a 15x8 rim in the rear and 255/70-15 on a 15x 7 inch rim in the front but I don't know the back spacing without the truck here at work.Anyhow no clearance issues though.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- Galaxie64
I've got some 17x9s with 265/70/17's on them that I put on my '51. Hopefully when the weather gets nicer, maybe Sunday, I am going to test fit them on the '72 I am curious if they fit. They just barely touch the frame on the front of my '51 at a full turn so you'd think it would fit in a '72 wheel well, although the '51 came with stock 17" rims. IIRC my backspacing is around 4".
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
