Driveshaft question
- AustinTom
Driveshaft question
Will the 2 piece driveshaft from a C-6 lwb truck fit one with a np435 or will it need to be altered?
- ICEMAN6166
re: Driveshaft question
depends if the c6 has a slip in yoke or a bolt up u joint type on the trans end i believe.as far as i know all the 435s are bolt on shafts.
You'll need a driveshaft that has the slip joint build into it.
- 390Nut
You'll need to at least change the yoke, as the C6 had either a slip yoke, or a flat, bolt on yoke, depending on the type of C6 (some had a short shaft tailhousing that has a flat, four bolt flange, more common to the trucks than cars, and some had a slip yoke).
The length will be a factor as well, and will likely need to be cut and have the joint flange rewelded (requiring a rebalance of the driveshaft assembly) or just find the proper driveshaft assembly elsewhere.
Paul
`69 F100 390 4spd driver
