Prop valve
19FORD67
Prop valve
Post by 19FORD67 »
can the prop be reused from the drums once i go to disc?
:fr:
'92 Mercury Cougar
no you need the disc version. the drum version is just a connector and doesn't do any thing about propotioning the fluids from front to back brakes.
19FORD67
re: Prop valve
Post by 19FORD67 »
Mind if I ask then, what difference is there from the disc valve?
:fr:
'92 Mercury Cougar
ICEMAN6166
re: Prop valve
Post by ICEMAN6166 »
the difference is the drum brake is simply a 5 way connector
while the disc brake has a valve inside to regulate the pressure.
19FORD67
re: Prop valve
Post by 19FORD67 »
ah, i see, thanks guys :thup:
:fr:
'92 Mercury Cougar
