clutch noise?
montana_hiboy
clutch noise?
Post by montana_hiboy »
my truck sat for a month and when i took her out today i noticed a noise coming from the clutch (i think) when the clutch is disengaged no noise is evident but when the clutch is engaged i hear a low pitched growling or grinding type noise, it's present in all gears, at all speeds.....any ideas, thanks
Jim
'75 Ford Highboy 390 4spd
ICEMAN6166
re: clutch noise?
Post by ICEMAN6166 »
time to crawl underneath and remove the cover and have a look inside the bell.
sounds like the throwout bearing lost its lube, or is rubbing on the pressure plate.
possible the clutch needs adjustment, especially if the cab mounts are rusted and sagging.
Heavenlyfire
Post by Heavenlyfire »
Yep, throw out bearing.
montana_hiboy
re: clutch noise?
the throw out bearing would only make noise when clutch is disengaged, this makes noise when clutch is engaged
Jim
Heavenlyfire
if the bearings are dry it might do it either way.
how's the fluid level in the trans?
jor
re: clutch noise?
Post by jor »
I was waiting for an answer on this one as I was thinking the same thing. However, if the clutch is out of adjustment, the throwout bearing could be making contact with the pressure plate fingers and spinning. Or I guess your input shaft in the tranny could be going. What have you found out thus far?
jor
montana_hiboy
re: clutch noise?
tranny fluid level checks out ok, i have'nt had a chance to take a look inside yet but i drove her over the weekend and the noise has going from be a constant noise to more of an intermittent noise, ill have a chance to take a closer look tommorrow though, i know it's kinda far fetched but i'm just hoping it's due to the truck sitting for a month in single degree temps and the niose just goes away with time......
Jim
Heavenlyfire
Sounds like it might stop. It has been cold and with it sitting that could have gummed up the grease in the throw out bearing. After it "recurculates" around the bearings you might be ok. Just a thought.
montana_hiboy
re: clutch noise?
well to update, as of monday the noise has completely vanished, and hopefully stays that way, these trucks are like a trusty 'ol mule, they like to be worked, they just don't like sitting around too long i guess :lol:
Jim
Heavenlyfire
Glad to here it. Now just keep driving and quit parking it lol
