Patching my drivers door
dduude
Post by dduude »
I had a go at getting rid if some of the rust through on my drivers door .It's the first one . It's got to get better and easier.
http://s131.photobucket.com/albums/p281/tailgaterdude/ 1968 F-100 302 ci, 3" dropped axles ,
'73 Disc Brakes '48 F-1 Roof ,69 Mach-1 hood scoop'92 Caddy Taillights ,4-Track Player
1948 F-1 W/Flat six
SMF Speed&Custom
Post by SMF Speed&Custom »
Looking good. Keep skipping around until it's welded up all the way around and grind it down, throw down your filler and smooth her down!
jzjames
re: Patching my drivers door
Post by jzjames »
Cherry. Wish you were my neighbor. Id definately enlist you to do my four corners. I went to the welder/rust repairer and he wanted $100 for each patch like you did. Then I thought- "thats not a bad price". :o
jor
Post by jor »
dduude, great photos. Please keep them coming along with a narrative on your experience on the patch panel.
jor
SMF Speed&Custom
The reason for the patch panels to cost so much for someone to do is because it is time consuming. Cutting it out, blasting it or POR 15 the inside, new patch cut out and weld in, grind smooth, bondo, sand, prime, etc etc. Lots of work and people don't realize that.
Big D's 69
Post by Big D's 69 »
I just found out on my 69 I have to do patch panels on the front and rear of the doors. I'm going the same route you are going with yours. Just a little time consuming, but no money involved since my time is free. Looks good.
