67 only?
67 only?
is the brake pedal a 67 only? i have the parts now to upgrade my 67 to power brakes via a 70 booster. will i have to use the 5/8 bolt to make it work like flyboy has suggested to others. or will it fit with the other bolt from either the 70 or the 67. what do i need to do exactly. i do have a 68-72 pedal i can put on if i have to. what is the best choice for trying to stay as close to original as possible.
re: 67 only?
To use a '70 booster in a '67, you'll need to use a '68-up brake/clutch pedal bracket. See the following thread for more info:
http://fordification.com/forum/viewtopic.php?t=3406
