i did. make as close a cut as you can, remember, you can grind more off, but once you go to far, your in a world of mess. when welding it back together, make short bead runs, skip around a bunch, spread out the heat, that will cause less heat distortion. grind and weld, grind and weld, grind and weld. about all there is to it.
word to the wise, DO NOT LET IT GET WET until after you have paint on it, you do not want it rusting out from the inside. do not ask how i know.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
