Swapping in blade fuse box.
rjewkes
Post by rjewkes »
I have the 82 T-bird She is pretty much a dieing car as the floor is rusting out under the seat and as she is an 82 just not the kinda bird you would restore.
The fuse box is just a hair wider than the original. Could i gety away with harvesting this thing and wiring my spare harness back into it one circuit at a time?
I'm also considering grabing everything that can be used on a truck including the duraspark set up.
fuelly.com
Re: Swapping in blade fuse box.
rjewkes wrote:...The fuse box is just a hair wider than the original. Could i gety away with harvesting this thing and wiring my spare harness back into it one circuit at a time?...
Why? :hmm: What do you hope to gain by doing so? Since the harnesses are completely different between the two vehicles, you'd still have to adapt your truck harness to it. It would be a major PIA and you'd still have to contend with the old truck harness. I see nothing to be gained and plenty to lose....but that's just my :2cents: FWIW.
rjewkes
Post by rjewkes »
i was hoping to have a newer fuse style and Have a dedicated fuse for my Radio's battery plus that didn't have to run all the way out the firewall.
But it does look quite challenging.
fuelly.com
adrianspeeder
Post by adrianspeeder »
Might find this handy...
http://fullsizebronco.com/forum/showthread.php?t=71989
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
rjewkes
Post by rjewkes »
I decided to stick with the opriginal fuse setup.
fuelly.com
