one question
72camperspecial
one question
Post by 72camperspecial »
would it be possible to hook up the electric choke to the under hood light? i have talked to my dad and he said that would work as long as i put a fuse there. if that won't work can i get a pic of where it is supposed to go? :?
72 F-250 Camperspecial
Factory Disc Brakes
Dual exaust with series 40 flows
flyboy2610
re: one question
Post by flyboy2610 »
It goes to the stator terminal on your alternator. That way it only gets juice when the engine is running, which is what you want.
Fake Name
Post by Fake Name »
With all due respect to flyboy, it will depend on the carb. Aftermarket Edel's want a full 12v accessory wire. You can even extend the + coil wire, if you've removed the resistor wire for an aftermarket coil.
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
72camperspecial
well, the carb is a holley and i don't know the mod number. if anyone could tell me what the stator terminal is i would appriciate it. i have no idea.
Factory Disc Brakes
68F250
re: one question
Post by 68F250 »
Here's the Holley conversion kit installation & adjustment instructions:
http://www.holley.com/data/Products/Tec ... 7972-4.pdf
Barry
