caulk or weld
caulk or weld
I have some rust issues under my drip rail just above the windshield rubber, in different spots along that line. Would I be safe, (water tight), if I just used caulking sealer or do I need to weld? Yes the rust put holes all the way thru. Any help is appreciated.
The ONLY true thing WE OWN and have to GIVE is our WORD. I did what others did not want to, and became what others could not, now the best "REVENGE TO WAR" is to live the best I can.
- Big D's 69
re: caulk or weld
re: caulk or weld
I don't know if I would weld inside the drip rail or not. I would probably clean up the spots real good, spray some rust convertor in there, and try to braze them with some silicon bronze rods. This may not be the easiest method but it woud prevent punching through with the welder and creating bigger holes. Also the bronze rods are better hole fillers.
Jayson
94 Cobra convertible Pace Car 300hp 302FI
07 Shelby GT 325hp 4.6L
58 Fairlane 292 Y-Block
65 Mustang 271hp 289
05 Excursion 4X4 XLT 6.0L
10 Camaro 1LT RS (wife's car)
76 Chevy Scottsdale 3/4 ton 4X4 350
- Big D's 69
I would probably just use fiberglass mat and resin after grinding them clean and treating them with rust convertor.
re: caulk or weld
It's under the drip rail and the rust went all the way thru, so i'm going to go ahead and weld em up, I thank ya'll for your input. I knew I should have started this sooner, next truck I will.
- dduude
re: caulk or weld
My rust was so bad the top blew off........
Ps I picked cherries down the road from you one season back in '75. Had a good time.Dude
re: caulk or weld
foggy
re: caulk or weld
TIG welding with stainless steel rod would work well. TIG welding doesn't put in as much heat as the others (MIG, arc, gas) therefor cutting down on warpage. The Stainless steel rod will burn out more impurities thus making a stronger weld
I love my "67
