Dash knob removal
Dash knob removal
How in the heck do the dash knobs come out? Lights, wiper, etc.? I need to paint the dash but I cant do the sanding and painting very easily around these things.
The truth shall set you free.
re: Dash knob removal
On the head lights there is a button on the switch behind the dash you push it and pull the knob and shaft out. As far as the others i would think that the knob screws off of the shaft. They make special sockets to remove the bezels that hold them on. But you can also use a good set of external ring pliers or file down the nose of a 90 degree needle nose pliers to fit and back them off.
foggy
foggy
- lrjetmech
I also have the same problem-the cargo light knob screwed off, but none of the other ones seem to, like the choke cable knob or the wiper knob. Anyone else have this problem, or additional info?
USMC, '83-87
'69 RANGER, Shortbed, 360, Manual, mostly restored already, LOVE IT!!!!!!!
http://www.fordification.com/galleries/ ... ?cat=11813
USMC, '83-87
i know the choke cable has a nut on the back side of the dash you have to unscrew
