Welded body seams?
F250MudPatrol
Welded body seams?
Post by F250MudPatrol »
Are there any other durable alternatives to welding the body seams? I want my truck to look good, but I am not confident enough with my welding abilities yet. I definitely want them filled. How?
The truth shall set you free.
flyboy2610
Post by flyboy2610 »
You might try something like JB Weld or Liquid Metal and use it as a body filler.
If rust DID get started though, it would be a real PIA to get that stuff out.
re: Welded body seams?
Personally, I think if you're not going to actually weld the seam, then your best bet is to use a regular body seam filler since you'll want it to remain semi-flexible. After you run a bead down the seam, you'll could run your finger down the seam to flatten out the bead and give it a slight concave contour.
F250MudPatrol
Thanks guys, keep slingin' slop.
Big D's 69
Post by Big D's 69 »
I have pondered the idea of using all metal. It is a body filler like bondo but much better for something like this. It is still sandable but a lot more durable than bondo or fiberglass.
ERICLDUFFEL
Post by ERICLDUFFEL »
What is the name of that all metal filler you are talking about using? :D
Big D's 69
All metal is the name of it.
Randle
Post by Randle »
One product you might think about trying is Metal 2 Metal, Eastwood handles it and it is made to fill seams and use were you used to use lead filler. It has aluminum and fiberglass particles mixed in it to give it more strength. I personally am going to weld mine and try to leave it a little below flush and then flush it out with Metal 2 Metal.
Randle
Dropped 68
Re: re: Welded body seams?
Post by Dropped 68 »
Randle wrote:One product you might think about trying is Metal 2 Metal, Eastwood handles it and it is made to fill seams and use were you used to use lead filler. It has aluminum and fiberglass particles mixed in it to give it more strength. I personally am going to weld mine and try to leave it a little below flush and then flush it out with Metal 2 Metal.
Randle
That sounds ilke a good idea in that you would likely eliminate the majority of flex that might occur between the two halves. Then by using the metal to metal you could better smooth the contours together. If you end up doing it post about it. I'm not that far along yet, I want bags first and foremost :twisted:
ERICLDUFFEL
Where do you get that ALL METAL product at.Is it in parts stores autzone oreiley's etc. :D :?
Big D's 69
ERICLDUFFEL wrote:Where do you get that ALL METAL product at.Is it in parts stores autzone oreiley's etc. :D :?
I know Car Quest and Napa carrys it.
tybob81
Post by tybob81 »
Eastwood has some stuff called lab metal that is pretty sweet. I just finished welding the vertical seems in the rear part of my bed on my 68 turned out pretty cool.
