stylside bed body seams weld smooth
tybob81
Post by tybob81 »
on my 68 I want to smooth the bed out a little more to look more custom. I have already shaved the stake pockets and now I want to shave the line that runs vertical on the back part of the bed were the taillight portion meets up. Has anyone done this or would recommending this. I have seen it on a few 67-72 just wondering
SmokeyBear
Post by SmokeyBear »
I've done it to two beds. It's definitely worth it not having to worry about the seam rusting out again.
70 F-100 XLT
72 F-100 Ranger XLT
lazyj70
re: stylside bed body seams weld smooth
Post by lazyj70 »
I've never thought about that but I like the idea. It will look smoother and cleaner. Just Do It!
2008 F-350 Lariat Crew Cab 4X4 Western Hauler
1970 F-100 Ranger XLT.
flyboy2610
Post by flyboy2610 »
http://www.fordification.com/my67-p63.htm
One thing Keith told me he learned was to only weld about one inch at a time and IMMEDIATELY quench the weld area. Then move to a cool spot and repeat the process. If you try to weld too long a bead and you don't quench the weld area, you will warp the panels.
Galaxie64
Post by Galaxie64 »
I plan on doing this but it sounds like it will take quite a while to let stuff stay cool enough. Cleaning out the seam will take plenty of time too I am afraid.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
tybob81
Post by tybob81 »
the bed is super clean and rust free because it has just came back from acid dip
layedout72
Post by layedout72 »
best way to do it is go front to back of each side, or even side to side front to back.
if you weld the driver side front a little, go weld the passenger side back, then the driver side back, then the passenger side front.
It is just like shaving a handle on your door.
Big D's 69
Post by Big D's 69 »
I'm shaving it all. Just grind it down and weld them up and then us body filler to smooth out the imperfections. Just be careful about getting the metal too hot and it warping.
zakt
Post by zakt »
I need to find an acid dip place local... Id dip my whole truck :D
1972 Ford F350 crewcab
tybob81
Post by tybob81 »
Thats what I did if I was going to resto my truck I was going to start with clean bare metal. I had every thing on my 68 dipped that was sheet metal even my spare body parts. I had the frame and suspension sand blasted.
rjewkes
Post by rjewkes »
I like that stuff nasa had on the shuttles the rubber like stuff.
fuelly.com
