Great info... more needed... am attempting to drop an AOD in behind my 289 in a 72 F-100. It currently has 3 on tree. here is my plan... am asking for a "sanity" check and any info or tips from the populace here. I do admire that you folks are willing and have the know how to share!
1. remove 2 part drive shaft
2. remove 3 on tree and associated clutch actuating parts
3. remove flywheel/clutch bearing
4. install new flex plate
5. install AOD with new x-member located and Lokar shifter
6. have "donor" shaft grafted to rear existing shaft/ install
7. install auto knockdown cable and hardware
8. Drive the snot out of it!
Anyone have experience here and want to share? I'd like to be able to shift at column, but haven't found auto column with manual steering truck yet. Thanx... Sgt_fixit
AOD in my 72?
re: AOD in my 72?
First things first if your engine is hopped up then you want your tranny strong enough to mate to it or you'll be replacing tranny's in no time. I am not completly sure but I believe you want to use the c4 cross member and move it the right distance to acomidate the lenght of the aod. As far the cables and connections you pretty much have it nailed. Good luck
- Clarko
Re: re: AOD in my 72?
The C6 and the AOD are about the same length. C6 crossmember will work for sure.gonzalo medina wrote:First things first if your engine is hopped up then you want your tranny strong enough to mate to it or you'll be replacing tranny's in no time. I am not completly sure but I believe you want to use the c4 cross member and move it the right distance to acomidate the lenght of the aod. As far the cables and connections you pretty much have it nailed. Good luck
Also, as far as a column, an early (like 67-early 69) power steering truck will work also, as long as the steering box is a Bendix box as opposed to the Ford/Saginaw box.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
re: AOD in my 72?
Thanx... engine is not hopped up at all. It's an 289 out of a 66 mustang. Was in really bad shape when I got it. Was jumping rope with it's own timing chain. haha I'm just trying to make it driveable. I'm currently reading ALL the tech articles on PWR steering. Anyone have a PWR steering column they want to get rid of? I'll head to the junk yard in the next month or so to gather parts!
re: AOD in my 72?
I went from a 3 speed, to a c6, to an AOD, a c4 and finally back to a c6 with the same trany cross-member. Just slid it back and forth a couple of times.
With the AOd in there you can go to a one piece drive-shaft also if you wanted. It is on the edge of being too long but mine worked fine with no vibrations after being balanced
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
re: AOD in my 72?
do u get better gas milage with a aod
- splavin90
well it's like a C4 with an overdrive. so yes. with an AOD, and the right rearend gears you could probably get 15-20mpg out of a 289, i know you can get 17-20 with a 300tynall44 wrote:do u get better gas milage with a aod
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
re: AOD in my 72?
I did'nt get any better mileage with one. I had the AOD behind a 351w with 3.70 gears and got the best of about 13.-14 mpg. Tried 3.25 gears and it got worse. I am running a 460-c6 with 3.0 gears right now and getting AT LEAST as good if not better mileage.
I need to check it but can;t get a full tank run out of it without 2 or 3 wide open blasts out of it.
Clint
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
