On the radius ar m the brackets that connect the shock to the radius ar m can be mounted so that either the shock sits "high" on the radius ar m or "low". I took apart the front end of my donor truck without noting which way it goes.
On my 68, the shock is mounted "low" and based on the RS and LS lettering on the bracket, I think that's how it is supposed to be on my 77 doner's front end. Can someone confirm?
From this picture of Keith's build, I think he's got the brackets switched around and installed on the wrong radius ar ms.
