Help! I rebuilt my p/s pump and now it's crazy.
So my p/s pump has had a leaky seal for a while and I finally decided to fix it. Took it apart, replaced seals, back together without too many problems, put it back in truck, filled with Type-F.
Now, when I start it up, here's what happens:
- No power steering at first.
- Starts to make a quiet whining noise, gets louder, as it gets louder I get more power steering. So I try to turn the steering fully to one end.
- It hickups fluid out the top of the dipstick tube once or twice while turning the wheel. Loud whining noise. Not very much power. Takes about 30 seconds to go all the way.
- Now, I try to go back the other way. It may or may not do this. It might just sit there with no power. If I turn the engine off, it overflows a massive amount of foamy fluid onto the ground.
I read through all the earlier posts I could find on here, and it kind've sounds like I've got air in the system. That's why I've been trying to go back and forth with the wheel. But it doesn't seem to be getting any better. I've gone back and forth maybe 5 times now. (It's about a 3 minute process, plus I've been letting it sit sometimes to get the foaming down.)
Is it possible that I put the pump back together wrong? Is there a better way to get air out? Is it time to bite the bullet and get a whole new pump?
Thanks for any help,
Joel
Joel
- heep70
Are the hoses connected to the right connections on the pump?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
I'd say you simply have air in the system that must be bled out. Normally this is easiest to do by getting the front end up off the ground, so when you work the steering wheel back and forth you're not fighting the friction of the tires on the ground. Then just turning the wheel lock-to-lock a dozen or so times will do it enough to bleed out a majority of the air. Normal driving will take care of the rest.
So I finally got the chance to put it up on jackstands. I turned the wheel lock-lock about 12 times. The first few times, it spat up a lot of fluid, but that eventually died down. I topped her off, dropped her to the ground, and...
No power steering.
Damn.
It's pretty close to impossible to turn the wheel while stopped. Once I get going, it can be turned, but takes some manhandling. I used to be able to drive with one finger!
I'm just about to bite the bullet and buy a whole new pump, but I don't want to start over at square one if there's a simple fix.
-Is it possible I re-assembled the pump wrong? Is it possible for ANYONE to re-assemble one wrong? There really seemed like only one way to do it...
-Is it possible that I damaged the pump by trying to turn the wheels while they were still on the ground?
Thanks,
Joel
No power steering.
Damn.
Thanks,
Joel
- 390Nut
If it's a 2wd truck, the crossmember under the engine will be perfect for lifting the front of the truck up. If you've got a decent floor jack, you can lift it far enough to get both tires to turn. If not, then use jack stands (or blocks of some sort, if you're feeling bravejwetzel1492 wrote:Is there a good place to put a hydraulic jack to lift the whole front end safely? I've only ever lifted one corner at a time.
Thanks,
Joel
Paul
`69 F100 390 4spd driver
Jewl: I just posted a factory service manual that might be helpful in diagnosing your problems:
http://fordification.com/forum/viewtopic.php?p=121149
Good luck....hope this helps.
