Removing Manual Steering Box
I believe I can get to one of my broken exhaust manifold bolts if I remove my manual steering box. Like most things on this truck, I have never done this before. Are there any tricks that I need to know, or can I just take it off and put it back on? '68, 4x2, 360.
- 72hiboy4x4
use a tie rod end remover to ...well, remove the tie rod. unless you are doing a steering rebuild, then you can just hit the side of the toe rod with a big hammer a couple times to pop it loose. don't forget to loosen the nut first!
