How do I remove my rear leaf springs?
I have the bed off my shortbed F100 to do some rust prevention work. I'm going to replace the leaf spring bushings while I'm at it. Is there anything I need to be aware of before I do this? It looks to be pretty simple but I thought I'd ask first! Thanks... Randy B.
re: How do I remove my rear leaf springs?
Lots of PB Blaster (NOT WD-40) to loosen up the rust. Other than that, it's as simple as it looks. The bolts will probably be difficult to drive out because of corrosion inside the bushings, so just work them back and forth instead of just trying to power them out with the hammer, or you'll end up having to replace them because you mushroomed the ends.
- SmokeyBear
Make sure you unload the suspension and only do 1 end at a time.
70 F-100 XLT
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- flyboy2610
Re: re: How do I remove my rear leaf springs?
What's the best way to do that?SmokeyBear wrote:Make sure you unload the suspension and only do 1 end at a time.
By lifting the back end up from the frame. You don't want to lift the rear tires off the ground, but probably want it up about half the way.
Thanks guys.. I took them off over the weekend then sanded, sandblasted and POR-15'd the entire frame! Next week I plan to sandblast the bed!
- flyboy2610
Thanks, Keith. I'll make sure to do that when I pull the 9" and springs out.FORDification wrote:By lifting the back end up from the frame. You don't want to lift the rear tires off the ground, but probably want it up about half the way.
