4:10 gears
- fourtss
4:10 gears
I found out today that my truck is a special order truck, came w/c6 tranny dana60 4:10 gears, then some dumb,a$$, pulled the auto and put in a 4 speed w/granny low, best I can figure it's the T-18 tranny, it runs about 3000 RPMs when cruisin down the road it's time to put my auto back in it.
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
2003 ford escape
- ToughOldFord
re: 4:10 gears
Won't change anything unless you put an overdrive in it. Any non-overdrive transmission standard or auto, have a 1 to 1 ratio when in high gear.
- fourtss
re: 4:10 gears
well guess I'll have to find me a set of gears then,
tom
2003 ford escape
2003 ford escape
- ToughOldFord
re: 4:10 gears
Yep. I had 4:10's myself, I switched to 3:73s. Didn't help much, dropped my RPM by 200 on the freeway. I should have gone with 3:55s.
- binder56jd
re: 4:10 gears
now serving #235
now serving #235
- willowbilly3
re: 4:10 gears
Or some really tall tires.
- DuckRyder
Guys,
Remember when discussing gear ratios, you must consider tire size.
a 4.11:1 in an F-100 with a 28" tire and a 4.11:1 in an F-250/350 with a 33" tire are two different animals.
- jzjames
re: 4:10 gears
Ive grown to like my 3.70 gears. Cruises nicely at 65. Like the torque.
Get a good exhaust and muffler. Consider some sound deadening insulation.
re: 4:10 gears
Im definetly changing my to a 3.55 from 4.10 for less wear and tear and better milage plus more highway speed the motor makes up for less gear
- flyboy2610
re: 4:10 gears
May I ask what the primary purpose of the truck is?
If it's for hauling, pulling loads, and other related work you may be better off staying with the 4:10's.
If it's a daily driver, then go to 3:55's.
- fourtss
re: 4:10 gears
it's a daily driver, I don't have a boat or camper anymore
but hopefully next spring I'll have another boat, I thinkin 3:73's
tom
2003 ford escape
2003 ford escape
- 67highboy
re: 4:10 gears
If you have a stout motor go with the 3.55 it will still haul anything you need to haul.
Ben Franklin 1775
Ben Franklin 1775
- fourtss
re: 4:10 gears
I think ur right highboy,I just rebiult a 360 and put a mild cam in er I think I will go with 3:55's
tom
2003 ford escape
2003 ford escape
Tranny w/a Granny
Ok guys, i'm a first timer, so you know what they say about stupid questions. I have the same setup, 4:10 rears, tranny w/a granny, 360mtr,(i'm rebuilding her to be a little more stout), so if i change to a c-6, i'll still have the same problem even if i change to 3:55's? The reason i'm asking is, i'm thinking of buying a 5th wheel trlr, i'm in a delima
can ya'll help, any and all will be greatly appreciated.
- fourtss
