Aircraft/plane stripper
jbrown414
Post by jbrown414 »
I've been told by a few DIY body work guys that aircraft/plane stripper is good for removing paint and getting down to bare metal. They say to paint it on, let it sit and then scrape the paint away. Has anyone heard or used this before? Is it recommended and could it really be that easy? Thanks in advance.
Jeremy
flyboy2610
re: Aircraft/plane stripper
Post by flyboy2610 »
Brake cleaner and a power washer would work pretty well, too! :lol:
layedout72
Post by layedout72 »
aircraft stripper is brutal. your hands or anything + aircraft stripper = one VERY VERY BAD day.
72hiboy4x4
Post by 72hiboy4x4 »
I used regular paint stripper from the hardware store last time I stripped a rig for painting. Was just that easy, but the fumes can kill you! Don't do this in the winter with the garage doors closed. (don't ask me how I know!) :lol:
flyboy2610
72hiboy4x4 wrote:I used regular paint stripper from the hardware store last time I stripped a rig for painting. Was just that easy, but the fumes can kill you! Don't do this in the winter with the garage doors closed. (don't ask me how I know!) :lol:
Or you'll wind up as goofy as the guy in your avatar! :lol:
Yes, it does work....but man does it create a mess....and fumes....and the possibility of leftover residue attacking the paint if you don't get it almost microscopically cleaned off afterwards.
Just chuck up a 3M composite stripping wheel in an angle grinder and go to work. It'll strip things down to bare metal in almost no time, and the only cleanup you have is to sweep up the dust.
FoMoCo
Post by FoMoCo »
Klean Strip makes the "Aircraft" brand.
There is a LOW ODOR version that will not burn your eye's out and is less runny, and stronger. It was made for shops that dont have a good vent system. You must buy NITRILE stripping gloves and never use rubber or latex when working with this stuff. The best way to apply is clean the area with 100 grit sand paper and use a paint brush to apply a thin coat.
Here's a tip. Once you brush it on leave it. Don't over lap your stokes. If you look carfully after making on pass with a brush you'll notice the surface developes a waxy looking film. This wax film holds the solvents, so continuous brushing breaks the wax and weakens the stripper. Oh, and dont waste time using the spray can version.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
stockr
Post by stockr »
i have used AIRCRAFT STRIPPER before...yes is smelling and bad.yes it creats a mess but if you use it properly you can get positive results..what i mean by using it properly i mean by using it in a good ventelated area but contained..put some cardboard on the the ground or something...oh yes dont forget to be well protected...pants,longsleeve,mask and goggle if you choose to wear them...
99 COBRA-DAILY DRIVER
95 F150 EDDIE BAUER-BAGGED
94 BRONCO EDDIE BAUER-FISHN TRUCK
71 F100 SWB- HAS BEEN POSTPONED
rjewkes
Post by rjewkes »
i tried some on the old 72 but it aint throgh one of my rear side Marker lenses.
fuelly.com
FormerMarine1981
Post by FormerMarine1981 »
I used Crest Chemical Stripper on support equipment in the corps. You could watch the paint bubble up and wipe it off with your gloved hand. But it can give you one hell of a burn so use it carefully and use a mask and face shield and plenty of ventilation.
Big D's 69
Post by Big D's 69 »
It works great on something that washing it down with laquer thinner is no problem on. DOn't get it around rubbers or lights or crevaces if your not tearing it completely apart. THis stuff will hide and ruin a new paint job. Works great on hoods and stuff that has flat surfaces to were using a stripping wheel might cause heat and pressure while leaning on the hood. Just wear gloves and try to get in a ventilated area.
fhoyt700
Post by fhoyt700 »
I just used Kleen Strip low oder Aircraft stripper gets 95% of the paint off.I washed it really good and dryed it with a towel.Burns hands but not a strong odor at all.They have it at AutoZone
cathynkeith
Post by cathynkeith »
mine was sanded to metal, took a long time but worth it.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
Aircraft stripper does work.
But these guys are right it makes a big mess and if you get any on you it will remove skin with equal efficiency.
Also if there is any body work under the paint you will have to strip and re-do the body work as well. I am assuming if you are taking it to metal you are going to do that anyway but if not better use a stripping wheel carefully...
rjewkes
Post by rjewkes »
I just got a syphon feed 5-150 psi Sand blaster kit at atwoods for 15.00 after tax and the fine white silica or silicate Sand for 7.55 per 80 lb bag at meeks.
plus got the bucket to load the sand in and the goggles and resperator for another 28.00 bucks.
fuelly.com
