opinion about floor
67heavystepside
opinion about floor
Post by 67heavystepside »
going to be putting a new wood floor in the bed of my step side. my father-in-law put a floor in it 15 years ago with pressure treated 7/8"ply wood. i want to go with the plywood, what my problem is plywood comes 4'x8', my bed wall to wall is 4'8", 4' fender hump to fender hump. should i cut the sheet in half long ways, and put an 8" strip down the center. or put the sheet to one side and put the strip on the other side. i know factory was separate boards.
Big D's 69
Post by Big D's 69 »
I would go with the seam in the middle with turning the sheets sideways. A shory piece is gonna wanna buckle and warp and be a weak link in the floor.
71 LONG BED
re: opinion about floor
Post by 71 LONG BED »
:yt: Down the middle would be stronger and look better.
John Member #1549
Image Image Image
SmokeyBear
Post by SmokeyBear »
Buy two sheets and put one seam down the middle.
70 F-100 XLT
72 F-100 Ranger XLT
67heavystepside
it sounds like yall are talking about useing 2 sheets. cut anf fit 1 to one side, then cut and but it up to the other for the other side. did't think about it that way.
binder56jd
Post by binder56jd »
:yt: I agree w/ smokey and if u can afford it, use marine plywood :$$: :$$:
now serving #235
67heavystepside
oh yah definitly going with the pressure treated marine plywood, drill and cut everything , then thompson water seal it to treat the exposed areas were i cut and drill. that is what my father-in-law did last time and got 15 years.
jzjames
Post by jzjames »
I'd center the full 4x8 sheet of plywood, and use 4" strips of hardwood on the sides. That would look good. Id leave a 1/2" gap between the ply and the two sidepieces so it would drain!
67heavystepside
it was done that way last time . those 2 smaller peices started rotting first.
REDNECKMOBILE
Post by REDNECKMOBILE »
I'm not sure what is in pressure treated plywood but there is salt in pressure treated wood and it will advance rust on any parts that are under it. My fathers bed was restored over 15 years ago with yellow pine boards, treated yearly with burnt motor oil and is still going strong.
jzjames
Re: re: opinion about floor
Post by jzjames »
67heavystepside wrote:it was done that way last time . those 2 smaller peices started rotting first.
Id get one of those long red oak boards from Leowes and rip it to the correct widths. Shouldnt rot or warp.
