3 on Tree Column Problems
My shifter on my truck which is a columnshift,It gets stuck in 1st going to second.Is it wearing out or something? I really dont want to cut a whole in the floor for a stickshift.
- jzjames
re: 3 on Tree Column Problems
Im going to give you what the Chilton manual says:
"Put the shifter in neutral, and go under the truck to where the steering column shift levers are (at the bottom of the steering column). There should be locating holes in those levers where you correct the alignment by inserting a 3/16 drill bit. Align the levers with the locating hole. Leave the drill bit in position.
*If your shift rods have threaded sleeves; adjust the sleeves so that they enter the levers on the tranny (in the neutral position) 'easily'. Then lengthen the rods out 7 turns of the sleeves and reinsert them at that point.
*If your shift rods are slotted; loosen the attaching nut, make sure the tranny shift levers are in neutral position, then retighten the attaching nuts.
Remove the guage pin (3/16 drill bit) and check operation of the shift linkage.
- trukcrazy
The bushings in the linkage could be worn out and allowing some sloppy movement. After checking all the pieces for wear and replacing what is needed, I would follow the procedure that jz explained above.
Mine will do the same thing if I make sloppy shifts. If you make sure you are in neutral before going to second, you shouldn't have any problems though. It's trying to shift 1st to 2nd without going through neutral that will get you stuck every time.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
I replaced the bushings,im still gonna work on it more though
- flyboy2610
Re: re: 3 on Tree Column Problems
Good point. If your cab has sagged, then your column is no longer in the same position relative to the tranny.Leadfoot wrote:the first thing I would check is your cab mounts
(Somehow that didn't come out right?
