Correct coil location, '72 bumpside
Electrical and Wiring Forum Archives
mytmatt
Post by mytmatt »
Could someone post, or post a link to, a picture of the correct coil location for a 1972 truck? Mine made it onto the firewall at some point in its past life. I'm sure that is not the correct place for it, seems like I have seen them on the manifold, around the front drivers side?. It's a 360/auto with AC, if that makes a difference.
Matt
flyboy2610
re: Correct coil location, '72 bumpside
Post by flyboy2610 »
http://www.fordification.com/galleries/ ... =526&pos=8
The coil on the 360 in my F250 is on the drivers side front, with the bottom of the coil facing the front of the engine, and about even with the front of the valve cover. This isn't the best pic, but maybe you can make it out.
mytmatt
Post by mytmatt »
Thanks Flyboy, yes I see it lurking under there. Anyone else?
72hiboy4x4
Post by 72hiboy4x4 »
:yt: I don't have a recent pic, but mine is in the same location on all my FE engines.
68F250
Post by 68F250 »
Here's some pics for reference. The coil bracket bolts on to that stepped boss on the left-front corner. The coil bracket has a corner loped off so it goes on only one way. The engine tag goes on top of the bracket pointing forward and then the bolt.
Barry
Sharkdance
Post by Sharkdance »
Here is mine. Not a stock manifold but the coil still mounts in the factory position.
http://www.fordification.com/forum/files/fespruce4.jpg
68F250 is right about the bracket only fitting one way. It also incorperates the hook for your carb return spring.
B.T.W.
68F250,
Thats one sweet looking engine you got there!
Sharkdance
70 F250 2WD 360/C6
mytmatt
Post by mytmatt »
Thanks very much for the pix, guys. I guess I'll have to find one of those brackets, or see what I can make. Don't want anything cheesy looking in my engine bay, but not hung up on "all original" either.
I agree that is a really nice looking engine compartment, 68F250.
Matt
68F250
Post by 68F250 »
Thanks Sharkdance and Matt but umm, I wish that were my engine compartment. :D
Those are file photos of a low mile '70 that was on eBay a while ago.
Matt, you can get a coil bracket off any Ford engine, they are all the same.
Barry
Re: re: Correct coil location, '72 bumpside
68F250 wrote:Thanks Sharkdance and Matt but umm, I wish that were my engine compartment. :D
Those are file photos of a low mile '70 that was on eBay a while ago....
Those pictures are saved to the site at the following URL, for those of you who haven't seen them:
http://www.fordification.com/70Explorer-358miles.htm
