Rangoon Red Shaker cans?
CJ,s 67 F100
Post by CJ,s 67 F100 »
Any one know of which parts houses have rangoon red in shaker cans?
I only need one can to paint our steering column.
dcbullet
Post by dcbullet »
You can get from an online vendor such as:
http://www.autopaintdirect.com/spray.html
I've ordered from them before and was satisfied with the match. It's a little hard to judge, however, since you are comparing it to 40 year old paint. And on the interior of my truck, at least, the factory did a crappy job of spraying. You can see through the paint in some areas.
CJ,s 67 F100
re: Rangoon Red Shaker cans?
Thanks dcbullet, If I cant find it locally, I will use this.
Galaxie64
Post by Galaxie64 »
Napa should be able to mix it for you in a spray can.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
CJ,s 67 F100
Thanks Galaxie64, I have the regional distribution center for Napa here in Mesquite. I didn't even know they did paint. I will check them out this week. Thanks again.
